libksdk_platform.lib: No such file or directory
1,426 次查看
tilakmarupilla
Hi there,
I'm using a FRDM KL82Z board was just trying a hello world program in Keil from the package downloaded and encountered the following error.
release\hello_world.out: error: L6002U: Could not open file ../../../../../lib/ksdk_platform_lib/mdk/KL82Z7/release/libksdk_platform.lib: No such file or directory
I followed the same path specified above and saw that libksdk_platform.lib isn't present.
from a similar question posted in forum, I made sure to build the platform package before building the main project files.
Please advise me where this is going wrong
标记 (1)
1,280 次查看
danielchen
Hi Tilak:
I would suggest you build libsdk_platform.lib first, make sure the build target is release, not debug,   then check whether the library is present.
If it is present, then build the hello world, release target.
