kinetic design studio debugging issue with MKE04Z64
1,231件の閲覧回数
ravindra
i am facing issue while software debugging by using kinetis design studio IDE with J link segger programmer and MKE04Z64 MCU
i am able to burn programme into mcu but problem comes only for debugging the code.
kindly help us to sort out the issue
1,213件の閲覧回数
nxf58904
First,we use a blinking example to make sure that your chip can work well.
Then,check the initialization of the chip . For example, if you use systick ,but you didn't init it ,the issue will happen.
Jianyu:
TIC
