is there any i2c (master) to spi (slave) bridge conerter
jhansipalepu
 we need spi(salve ) to i2c(master) converter for one of our applications,
Is there any module available like that?
we found i2c(slave) to spi(master) converter SC18IS602B. But our application require in other way.
Can anyone please provide us the info regarding this.
Thanks & Regards,
Jhansi Palepu
reyes
Hi Jhansi Palepu,
The SC18IS600 is an SPI slave to I2C master bridge IC. This works in the other wat than then SC18IS602B.
You can find the device datasheet in the following link: https://www.nxp.com/docs/en/data-sheet/SC18IS600.pdf
Jose
NXP Semiconductors
