is need external programmer
parthibankandas
hi,
  i am entirely new to freescale semiconductor and i like to develop my knowledge in freescale. For that i choose to buy
MEMS Sensors Evaluation Kit with Freescale FRDM-KL25Z Freedom Platform kit. is this kit need any external programmer?, can i do programming without external programmer?
kerryzhou
Hi Parthiban kandasamy,
     If you use FRDM-KL25Z, you don't need use other programmer, because the boad has the sophisticated OpenSDA Debug interface.
    About detail, you can refer to the FRDM-KL25Z User's manual, the link is :
     http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=FRDM-KL25Z&fpsp=1&tab=Documentation_T...
I wish it helps you!
Best regards!
Jing
kerryzhou
Best regards!
Jing
parthibankandas
thank you jingjing, its perfectly gave the answer which i need.just drag and drop application into bootloader then bootloader updates previous programmer am i right?
kerryzhou
    Yes, you are right. If you put the MSD-FRDM-KL25Z_Pemicro_v105.SDA into bootloader, you can send the xxx.srec to the bootloader, then the boader will run the according program.
and if you need debug, you should choose DEBUG-APP_Pemicro_v102.SDA into bootloader,then you can debug through the IDE(eg.CodeWarrior V10.x,IAR ARM Workbench or Keil MDK-ARM ).
You still can find detail information from openSDA user's guide ,the link is :
http://cache.freescale.com/files/32bit/doc/user_guide/OPENSDAUG.pdf?fpsp=1
Best regards!
Jing
