is MKM34Z256VLL7 having the metering Lib in open source ?
1,740 次查看
nickng
there is only a static lib provide.
What if I need some modifications to fit with our won usage, is that possible to compile the Lib's source by ourself?
4 回复数
1,570 次查看
miduo
I am not quite sure what the metering Lib you mentioned. Please provide as many information as possible. Thanks.
1,570 次查看
nickng
Hi Fang,
please read https://www.nxp.com/docs/en/application-note/AN5007.pdf
To be more specific the lib  is with another app note : AN4265SW
They provide static metering library only. If it is a open source Lib, where can I find out the source?
1,570 次查看
miduo
The meterlib library source code need to sign a NDA agreement.
After you sign the NDA agreement, you could contact with your local NXP Distributor to get the source code.
The distributor network could be found from: Distributor Network|NXP
1,570 次查看
giordano_wolani
Do you know if they have an exaple of energy metering with M34Z256 and MCUXPRESSO? I am developing a energy meter, but using their libraries, wonder to know if there is an open source alternative.
