Hi, Tom,
From all the description including Norm and Martyn, I see that you are using KDS tools to develop the code. If it is the case, as Mr Norm Davies suggested, after you installed KDS, you have to install SDK, which is code generator and library. In the SDK, there is a lot of example, the CMSIS is one of the directory.
after you installed SDK, pls refer to the example
C:\Freescale\KSDK_1.0.0\demos\sai_demo\kds\twrk64f120m, the equalizer.c use the CMSIS to develop FFT, it is helpful to understand how to call FIR. I copy the code here:
You can refer the FIR code:
C:\Freescale\KSDK_1.0.0\platform\CMSIS\DSP_Lib\Source\FilteringFunctions
Pls download SDK from the the website:
http://tinyurl.com/kd79d7y
equalizer.c
* Standard C Included Files
#include <string.h>
#include <math.h>
#include <stdbool.h>
#include <stdlib.h>
#include <stdio.h>
* SDK Included Files
#include "fsl_soundcard.h"
#include "fsl_sai_driver.h"
#include "fsl_sai_features.h"
#include "fsl_sgtl5000_driver.h"
* Application Included Files
#include "audio.h"
#include "equalizer.h"
#include "terminal_menu.h"
* Include CMSIS-DSP library
#include "arm_math.h"
* Global Variables
* Function Definitions
float32_t do_fft(sai_data_format_t *dataFormat, uint8_t *buffer, float32_t *fftData, float32_t *fftResult)
/* Counter variable for navigating buffers */
uint32_t counter;
/* Return value for wav frequency in hertz */
float32_t wavFreqHz;
/* CMSIS status & FFT instance */
arm_status status; /* ARM status variable */
arm_cfft_radix2_instance_f32 fft; /* ARM FFT instance */
/* Frequency analysis variables */
float32_t maxValue; /* max value for greatest FFT bin amplitude */
uint32_t testIndex = 0; /* value for storing the bin location with maxValue*/
uint32_t complexBuffSize = AUDIO_BUFFER_BLOCK_SIZE * 2;
uint32_t fftSize = AUDIO_BUFFER_BLOCK_SIZE; /* FFT bin size */
uint32_t ifftFlag = 0; /* Flag for the selection of CFFT/CIFFT */
uint32_t doBitReverse = 1; /* Flag for selection of normal order or bit reversed order */
uint32_t sampleRate = dataFormat->sample_rate; /* Get sample rate from current format */
float32_t hzPerBin = 2 * ((float32_t)sampleRate/(float32_t)fftSize); /* Calculate hz per FFT bin */
uint8_t *temp8; /* Point to data for 8 bit samples */
uint8_t temp8Data;
uint16_t *temp16; /* Point to data for 16 bit samples */
int16_t temp16Data;
uint32_t *temp32; /* Point to data for 32 bit samples */
int32_t temp32Data;
/* Set status as success */
status = ARM_MATH_SUCCESS;
/* Wav data variables */
switch(dataFormat->bits)
case 8:
temp8 = (uint8_t *)buffer;
temp8Data = 0;
/* Copy wav data to fft input array */
for(counter = 0; counter < complexBuffSize; counter++)
if(counter % 2 == 0)
temp8Data = (uint8_t)*temp8;
fftData[counter] = (float32_t)temp8Data;
temp8++;
else
fftData[counter] = 0.0;
/* Set instance for Real FFT */
status = arm_cfft_radix2_init_f32(&fft, fftSize, ifftFlag, doBitReverse);
/* Perform Real FFT on fftData */
arm_cfft_radix2_f32(&fft, fftData);
/* Populate FFT bins */
arm_cmplx_mag_f32(fftData, fftResult, fftSize);
/* Zero out non-audible, low-frequency noise from FFT Results. */
fftResult[0] = 0.0;
/* Find max bin and location of max (first half of bins as this is the only valid section) */
arm_max_f32(fftResult, fftSize, &maxValue, &testIndex);
break;
case 16:
temp16 = (uint16_t *)buffer;
temp16Data = 0;
temp16Data = (int16_t)*temp16;
fftData[counter] = (float32_t)temp16Data;
temp16++;
else
fftResult[0] = 0.0;
break;
case 32:
temp32 = (uint32_t *)buffer;
temp32Data = 0;
temp32Data = (int32_t)*temp32;
fftData[counter] = (float32_t)temp32Data;
temp32++;
else
fftResult[0] = 0.0;
break;
default:
__asm("NOP");
break;
if(status != ARM_MATH_SUCCESS)
wavFreqHz = 0; /* If an error has occured set frequency of wav data to 0Hz*/
printf("\r\nFFT compuation error.\r\n");
else
wavFreqHz = testIndex * hzPerBin; /* Set wavFreqHz to bin location of max amplitude multiplied by the hz per bin */
return wavFreqHz;
* EOF
