Hello, i installed kinetis design studio and i'm trying to create new projects for kw41z mcu. Unfortunately when i create a new kinetis project and i try to select processor name i read many mcu name but there is not kw41z.
How can i add support in kinetis design studio for this micro?
Best regards and thank you
Hi Estephania,
I am also having this issue and I just need the MCU support in KDS.
Thanks.
The connectivity software it's not supported in the Kinetis Design Studio, you will need to use either MCUXpresso or IAR?
Estephania
Estephania I did not ask about the connectivity software. All I want to do is create a new project with a KW41Z processor. I had this working on my old computer but when I installed everything on my new computer the only support is for a KW40Z.
You can download the SDK for the KW41Z in this link, you will need to look for the Kinetis KW41Z Connectivity Software, nonetheless, that connectivity stack it's no longer supported.
Estephania
Are you looking for the connectivity software support in KDS or just the MCU support?
Estephania
