get last program
get last program
artemivashov14
How to get the program already recorded in FRDM-KL25z. need to copy this code to another board. How to do it?
nxf56274
If the code is encrypted, you can't read back. If not, you can use the segger to read back. You can serach the information about the segger to know how to use it. The usage of segger is not in our charge.
TIC
artemivashov14
I can’t do it. cannot connect to the library.
nxf56274
Segger is not in our charge. You should consult SEGGER.
TIC
