FRDM-KE06Z Bootloader Error
jun1
Contributor V
Hi.
Thank you for your help.
FRDM-KE06Z will cause an error. When the USB cable is connected, the LED blinks 8 times and then stops and repeats. The LASTSTAT.TXT at that time is programming ...
Attach the INFO file at that time.
Please tell me what to do.
jun.
jingpan
Hi jun,
Please download FRDM-KE06 openSDA firmware application from OpenSDA Serial and Debug Adapter | NXP .
There is a guide in this page shows how to copy the application into openSDA.
Jing
jingpan
Hi jun,
Jing
aleedrc
Hi! I tried to copy the application following step by step , and when I reconnect the usb nothing happens, im using windows 10
and im using FRDM-KL46Z
