flex memory in debug
2,835 次查看
kristies1
I have flex memory in K60 partitioned as eeprom, and would like the dflash to not be erased when debugging with CW10.2.
Currently every time I start a new debug session the dflash is erased, and losing all eeprom contents.
How can I keep CW from erasing the dflash?
Kristie
2,297 次查看
BlackNight
Beside of using a Target Task, you can use a setting to preserve regions of your flash:
Programming part of flash | MCU on Eclipse
Hope this helps,
Erich
2,298 次查看
kristies1
Thanks for the reply.  I had range error problems with the non-volatile memory preservation, but that page helped.
2,298 次查看
pbanta
Hi Kristie,
I use Target Tasks to accomplish this on my K70FX project.  You can create a Target Task and associate it with a debug configuration.  It gives you total control over what is erased/programmed to a sector boundary.  You can find info about Target Tasks here:
CodeWarrior Tool Tip #2: Programming flash memory is easy « The Embedded Beat: Freescale B...
Good luck.
Paul
