flash download failed
2,956件の閲覧回数
lifeng
mdk 5.14,  KE18F512VLL16, JLINK,  flash download failed.
my power and reset circuit
JLINK SET
Why?
2,776件の閲覧回数
kerryzhou
Hello Li Feng,
   MKE18 is the new chip, maybe your JLINK can't support it, especially if it is not the official version.
   I think you can update your JLINK driver to the newest one from:
www.segger.com
  Then use the JLINK commander, check whether you can find the KE18 board, and whether you can use the jlink commander: loadfile filename.bin
to download the code successfully?
  JLINK opensda v2 is the TWR-KE18F on board debugger(JLINK).
  I don't know whether you have the official board TWR-KE18F board on your side, if you have it, you can try it.
Kerry
3 返答(返信)
2,776件の閲覧回数
kerryzhou
Hello Li feng,
    I also test my TWR-KE18F with the KSDK2.2 MDK project.
   This is my test result:
From your picture, it seems your problem is caused by the flash address 0x1c, 0x1d,0x1e,0x1f. Your content is 0X00, my I have check my these address data, it is also 0X00.
 So, I think you can try the SWD method, and don't select the verify code download like me again.
  If you are still not OK, you also can try our KSDK sample code for TWRK-KE18F which can be downloaded from this link:
Welcome to MCUXpresso | MCUXpresso Config Tools
Click SDK build, choose the board as TWR-KE18F, then generate the code and download it.
Take an example, you can use the gpio code: SDK_2.2_TWR-KE18F\boards\twrke18f\driver_examples\gpio\led_output\mdk
Please try again on your side.
Any updated information, please let me know!
Kerry
2,776件の閲覧回数
lifeng
Hello Kerry Zhou:
     The tools is Jlink V9 from taobao,  I think whether it can't support MKE18F512VLL16  well.
      I can't find the JLINK OPENSDA V2 that you used tools in NXP web, Where to buy the JLINK OPENSDA V2 ?
2,776件の閲覧回数
kerryzhou
Hello Li Feng,
www.segger.com
Kerry
