eGUI: a menu.
eGUI: a menu.
2,088件の閲覧回数
john71
Senior Contributor I
I use TWR-K70F120.
I want to create a menu on LCD in my project and navigate through the items with buttons.
So I created the items as LABEL objects.
D4D_DECLARE_STD_LABEL(scr_entry_lblItem1, "ITEM 1", LBL_ITEM1_POSX, LBL_ITEM1_POSY, LBL_ITEM1_SIZEX, LBL_ITEM1_SIZEY,  (D4D_OBJECT_F_VISIBLE | D4D_OBJECT_F_ENABLED | D4D_OBJECT_F_FOCUSRECT), NULL, FONT_BERLIN_SANS_FBDEMI12_HIGH, NULL, NULL)
D4D_DECLARE_STD_LABEL(scr_entry_lblItem2, "ITEM 2", LBL_ITEM2_POSX, LBL_ITEM2_POSY, LBL_ITEM2_SIZEX, LBL_ITEM2_SIZEY, FONT_BERLIN_SANS_FBDEMI12_HIGH)
D4D_DECLARE_STD_LABEL(scr_entry_lblItem3, "ITEM 3", LBL_ITEM3_POSX, LBL_ITEM3_POSY, LBL_ITEM3_SIZEX, LBL_ITEM3_SIZEY, FONT_BERLIN_SANS_FBDEMI12_HIGH)
How can set focus for the current item? By changing the fore color or the background color? And how do I do it?
When I choose the item with an ENTER button  a new screen should pop up. As I understand all screens created ones stay in the memory – so I just call the screen (D4D_ActivateScreen(&screen1, D4D_TRUE);)?
Is there an example to create and navigate a menu?
1,957件の閲覧回数
LuisCasado
1,957件の閲覧回数
john71
I see. Thank you. The example uses a MENU object. I create a menu with LABEL items. This way I can place and orientate the items as I want. So what I need is an example how to operate LABEL (or TEXT) object as a menu items. And how to set focus on an item to visualize the selected item.
