eGUI - D4D_SetText doesn't work for Label object (v3.0)
2,073 次查看
Maciek
I'm updating label content (label text) depending on what button was pressed and some other data.
On each update, the updated (new) text overlaps the old text (or 'superposition' of previous texts) - I get superposition of both texts on the screen.
I would expect that the old text should be erased, and only the new one should be visible on screen.
I've checked both: D4D_SetText and D4D_LabelSetText.
There is no such problem with the Button widget...
I don't think this is the expected behaviour - or maybe I don't understand the widget behaviour ?
Maciek
1,808 次查看
LuisCasado
Change in d4d_user_cfg.h
#define D4D_LBL_FNT_PRTY_DEFAULT  ( D4D_FNT_PRTY_TRANSPARENT_YES_MASK )
By:
#define D4D_LBL_FNT_PRTY_DEFAULT  ( D4D_FNT_PRTY_TRANSPARENT_NO_MASK )
Luis
1,809 次查看
LuisCasado
By:
Luis
1,808 次查看
Maciek
Thanks for help. It works.
Maciek
