eDMA channel idle
eDMA channel idle
1,617件の閲覧回数
martindusek
how to check whether a dma channel is free to execute new DMA request? I thought about using ACTIVE and DONE bits of CSR register, but it seems they are not suitable for that.
Checking DONE == 1 works only when there was previous DMA transaction (it doesn't work if the DMA channel hasn't been used yet).
And ACTIVE is set to 0 on minor loop completition. I want something that tells me all major loops (whole tranaction) has been completed.
Thanks for help.
1,519件の閲覧回数
mjbcswitzerland
Specialist V
You could do a single dummy transfer during system initialisation in order to prepare the DONE bit and then use it as flag during subsequent operations.
Mark
1,519件の閲覧回数
martindusek
Hi Mark,
thanks. I'll do it If this is the only possibility...
