difference between FN et FX for kinetis K66, difference K26 and 66
1,812件の閲覧回数
PO220
In the datasheet, the only difference I see between FN et FX for K66 kinetis is the size of the flash memory (2MB vs 1.25MB). am I right ?
Is the presence/absence of ethernet periphera the only difference between K66 and k26?
Thank you in advance for your confirmation
タグ(2)
1,574件の閲覧回数
Jonathan_Iglesias
Hi PO220,
hope you are doing great.
You have some differences, some versions (this depends on the part number) have tamper detection,support IEEE standard like mac(1588) or timer(1588), what you are asking about the FN and FX the difference here is that the FN is flash memory and the parts with FX have flex memory (FTFE configuration that supports data flash, EEPROM, and FlexRAM).
Kinetis<sup>&#174;</sup> K26 MCU Family Block DiagramKinetis<sup>&#174;</sup> K65/K66 MCU Family Block Diagram
hope this works, have a great day !!
