configuring both EID and SID ID in mscan filtering.
688 次查看
Naveen158
I am receiving both EID and SID messages, if to congigure SID or EID separately there is an option for that but how do we do it if wanna receive both? and how should the filter and mask value be calculate for this case?
653 次查看
xiangjun_rong
Can you tell us the part number? there are multiple CAN IPs, the configuration is dependent on  CAN IP.
XiangJun Rong
