ZB_MENP_KW41Z IAR project help
ramkumarsubrama
I have the NXP modular gateway eval kit and I was trying modify the IAR project file ZB_MENP_KW41Z_Clickmodule. Before modifying the file I tried to compile the existing project and had no errors. But when I tried to download and debug using IAR i get an error "x bytes downloaded into flash and verified y bytes/sec" (see attached). When I was looking for solution i found a recommended fix to enable_config_write in debugger options and I did implement it. But still i have issues. Sincerely appreciate some help.
Tags (3)
stephanie_m
Could you please submit your question to this NXP Modular IoT Framework  community ?
You will need to join first and then post the question. All the questions regarding the gateway need to be placed there.
Estephania
