Hi @jingpan ,
Thank you for your prompt answer incl. the stability criteria.
I understand that the procedure recommended by NXP papers neglect Cin, Cout and if I want to include them, you would recommend me to use the one from the IBIS file.
So here is my last question about this IBIS file, could you please verify my understanding?
1) I would use the C_pin given at the pin 11:EXTAL and 12:XTAL (as we have the 64 LQFP)
that have 3.346e-13 and 3.336e-13F respectively.
2) But do I have to take into account C_pkg, or add it?
3) Do I have to take into account C_comp typical, or add it?
3.1) If I follow the model definition of p_io_5ma_model -> p_io_5p0_5ma as we use 5V
3.2) If I follow the model definition of p_io_5ma_model -> p_io_3p3_5ma as I saw the clk waveform is under 3.3V
Thank you for your answer,
