Workaround for e6939 Kinetis mask 3N96B
kappa74
Good morning,
I have this situation in my code which depends on the errata e6939 for mask 3N96B.
Sometimes, when an interrupt occurs, it will damage the value of one my local variable.
I use a K60 with mask 3N96B.
Is there any workaround in C language or any setting for compiler?
I used KDS 2.0 and the library MQX4.1.1.
Thank you
