Who has the "SCB Register" technical datasheet?
1,812 次查看
thoomanwang
Contributor V
1,611 次查看
Kan_Li
Hi Thooman Wang,
Would you please specify which module you are referring to? Thanks for your patience!
Kan
NXP Technical Support
1,612 次查看
Kan_Li
Hi Thooman Wang,
Kan
