Which softwares I should install in order to load Binary code into on-board MCU
769 次查看
linda1
Hi Team,
  I tried to debug KW45B41Z using JLINK, and now I follow the Getting Started KW45 Manual, load firmware to Code.
  Looking forward to your reply.
731 次查看
Ricardo_Zamora
Hope you are doing well. Could you please clarify if you are having any issue?
Were you able to follow the Getting Started with the KW45B41Z Evaluation Kit?
Ricardo
