What to do when swap process has problems?
1,576 次查看
eengineer
I have over the wire update with Flash swap generally working on a K64.
If my process encounters a problem, I am unclear on what the most appropriate steps are to invalidate the process properly, such that I can continue operation with existing code, and still have the option of trying to reflash later. I do not find that AN4533 gives any useful suggestions on this.
Should I simply erase the whole block of flash on which I was working?
Should I erase just the flash indicator(s)?
1,498 次查看
Jorge_Gonzalez
In case of an error condition situation when using the SWAP system, indeed you can simply erase the corrupted flash block and reprogram the firmware again. Please see a similar discussion in the next thread:
https://community.nxp.com/thread/430188
Let me know if any doubts.
Regards!
Jorge Gonzalez
