What is "direct boot valid" / KL17
1,265 次查看
jaakkoeskelinen
When looking at the Kinetis Bootloader Startup-up Flowchart (§13.3.4, p.178), there's a decision box with "Is direct boot valid?"  How is this determined (what makes the direct boot valid, i.e. enable check on the peripherals for activity; and how to disable this check +)
1 回复
1,204 次查看
Hui_Ma
I am checking with KL17 product team about "direct boot". I will let you know later.
Thank you for the patience.
Ma Hui
