What do I do with the Die attach pad?
1,306件の閲覧回数
gigatech
Fresh Out Contributor
Hi guys, Nooby question here, should be pretty straightforward. I'm building a teensy powered device of my own and am currently creating an eagle component for the MKL02Z32VFG4 bootloader chip. What on earth do I do with the Die attach pad on the bottom? I'm guessing I want to connect it to to the board to disperse heat but should it be connected to ground or am I wrong entirely? Many thanks, Giga.
1,230件の閲覧回数
vicentegomez
The recommendation is connected to ground, please check
AN2467
