What are the differences between the MK52DN512 and MK52DN512Z? Is there someplace the differences are summarized?
1,441 次查看
pk2
What are the differences between the MK52DN512 and MK52DN512Z?  Is there someplace the differences are summarized?  I need no migrated to the non Z version of the part and I am trying to determine what firmware changes will be required if any.
标记 (2)
1,316 次查看
adriancano
You might find this thread useful:
Code Warrior - Guide to rebuild code for Kinetis rev2 (non-Z) parts
HERE you can find the referred AN445 document
Hope this information can help you
Adrian Sanchez Cano
Technical Support Engineer
1,317 次查看
adriancano
Adrian Sanchez Cano
