Wake up from VLPS by usbhs resume
nenad
I'm using usb library for high speed in freertos environment on MK66FX.  Task puts mcu in sleep state when get suspend event and attach flag is set, but resume interrupt doesn't wake up mcu from sleep. I set USB_DEVICE_CONFIG_LOW_POWER_MODE to 1, do i need to set something else?
Labels (2)
danielchen
Hi Nenad:
I would suggest you check the USBHS clock on your board, whether it can work on VLPS mode
