**WARNING!** Bug Kinetis Bare Metal Same Code for SAI KINETIS_50MHZ_SC
1,233 次查看
eli_hughes
Contributor V
This applies to
Kinetis 50MHz bare metal sample code.  Size (K): 39831 Format: zip Rev #: 1.5 Modified: 4/2/2013
The function sai_mclk_config has a parameter "divide".    the variable is declared as a unsigned char but need to be at least a uint16_t.     The Divide portion of the I2S_MDR_REG is 12 bits in length so parameter needs to be able to store a bigger value.
1 回复
1,072 次查看
Hui_Ma
Hi Eli,
Thank you for the info.
Our Kinetis product team has known this issue, we are in processing to fix that issue in updated SAI driver.
Ma Hui
