Using PWT module
Using PWT module
1,838 次查看
ricardcomas
Hi everyone, i don't get PWT work,i must initialize module and get result of PPW with function PWT_PDD_GetPositiveWidth(PWT_BASE_PTR), REALLY?¿ o don't need interrupts here, i need get value by polling, i found this code:
Its look like a lot basic, how can use correctly?¿
I need get positive pulse width by polling,so i tought only init component and get its value.
Have a sample code somebody?¿
thanks so much
标记 (3)
1,709 次查看
Robin_Shen
Hi Ricard Comas,
You may need to polling check the state of PWT_R1[PWTRDY].
PWT_PDD_GetInterruptFlags function can be used.
I don't have the PWT sample code using Processor Expert. But you can find the PWT_demo in FRDM-KEXX-Driver-Library-Package(...\FRDM-KEXX-Driver-Library-Package\ke_drv_lib\build\iar\ke06\PWT_demo)
For more detail, please read "27.4.2 Edge detection and capture control" of MKE04P80M48SF0RM.
Robin
