Using Internal Flash as Non-Volatile Memory
javervalino
Im currently using kl15 in my project and unfortunately it doesn't have eeprom. My project require some strings that need to be save in a nonvolatile memory so I can still access it even after a power interruption.
Erich give a good example here "Configuration Data: Using the Internal FLASH instead of an external EEPROM | MCU on Eclipse". The problem I'm encountering right now is saving a string using this code. Can someone give an insights on how to obtain it.
Thank you very much.
javervalino
perlam_i_au
Senior Contributor I
Could you please be more specific? share your code? At this moment I was not able to understand what is your exact problem.
javervalino
Hello Perla,
Thanks for the response.. Its now answered by Erich here..Configuration Data: Using the Internal FLASH instead of an external EEPROM | MCU on Eclipse
