USBHS on K26 about 0N65N Mask-Errata #e9712 (unlocking USBPHYPLL if MCG_C2[EREFS]= 0)
2,106 次查看
Sedorf
In my project the OSC is working with a 24MHz crystal, therefore MCG_C2[EREFS]= 1, but the routine builded in MCUXpresso 11.10.0 [build 3148] with SDK v.2.11.0 m.v.3.9.0 fall in infinite loop /* Wait for lock. */ even if crystal otion OSC selected (MCG_C2[EREFS]= 1):
/*FUNCTION**********************************************************************
* Function Name : CLOCK_CONFIG_EnableUsbhs0PhyPllClock
* Description : This function enables the internal 480MHz USB PHY PLL clock.
* Param src : USB HS PHY PLL clock source.
* Param freq : The frequency specified by src.
*END**************************************************************************/
static void CLOCK_CONFIG_EnableUsbhs0PhyPllClock(uint32_t freq) {
USBPHY->PLL_SIC &= ~USBPHY_PLL_SIC_PLL_BYPASS_MASK; /* Clear bypass bit */
USBPHY->CTRL &= ~USBPHY_CTRL_CLKGATE_MASK; /* Clear to 0U to run clocks */
while (!(USBPHY->PLL_SIC & USBPHY_PLL_SIC_PLL_LOCK_MASK))
The workaround suggested in 0N65N Mask-Errata #e9712 not run.. possible?
Suggestions?
标记 (1)
2,055 次查看
Sedorf
Solved!
Both VREGIN0/1 are without supply, this make difficult to USB PHY operate!
2,056 次查看
Sedorf
Solved!
2,046 次查看
Sedorf
..and VBUS1 withou supply!
%3CLINGO-SUB%20id%3D%22lingo-sub-1963486%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EK26%20%E4%B8%8A%E7%9A%84%20USBHS%20%E5%85%B3%E4%BA%8E%200N65N%20Mask-Errata%20%23e9712%EF%BC%88%E5%A6%82%E6%9E%9C%20MCG_C2%5BEREFS%5D%3D%200%EF%BC%8C%E5%88%99%E8%A7%A3%E9%94%81%20USBPHYPLL%EF%BC%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1963486%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%9C%A8%E6%88%91%E7%9A%84%E9%A1%B9%E7%9B%AE%E4%B8%AD%EF%BC%8COSC%20%E4%BD%BF%E7%94%A8%2024MHz%20%E6%99%B6%E4%BD%93%EF%BC%8C%E5%9B%A0%E6%AD%A4%20MCG_C2%5BEREFS%5D%3D%201%EF%BC%8C%E4%BD%86%E5%9C%A8%20MCUXpresso%2011.10.0%20%E4%B8%AD%E6%9E%84%E5%BB%BA%E7%9A%84%E4%BE%8B%E7%A8%8B%5Bbuild%203148%5D%20%E4%BD%BF%E7%94%A8%20SDK%20v.2.11.0%20mv3.9.0%20%E9%99%B7%E5%85%A5%E6%97%A0%E9%99%90%E5%BE%AA%E7%8E%AF%20%2F*%20%E7%AD%89%E5%BE%85%E9%94%81%E5%AE%9A%E3%80%82*%2F%20%E5%8D%B3%E4%BD%BF%E9%80%89%E6%8B%A9%E4%BA%86%E6%99%B6%E4%BD%93%E6%8C%AF%E8%8D%A1%E5%99%A8%20(MCG_C2%5BEREFS%5D%3D%201)%EF%BC%9A%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CDIV%3E%3CDIV%3E%3CP%3E%3CSPAN%3E%2F*%E5%8A%9F%E8%83%BD**********************************************************************%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E*%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E*%20%E5%87%BD%E6%95%B0%E5%90%8D%E7%A7%B0%EF%BC%9ACLOCK_CONFIG_EnableUsbhs0PhyPllClock%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E*%20%E6%8F%8F%E8%BF%B0%EF%BC%9A%E6%AD%A4%E5%8A%9F%E8%83%BD%E5%90%AF%E7%94%A8%E5%86%85%E9%83%A8%20480MHz%20USB%20PHY%20PLL%20%E6%97%B6%E9%92%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E*%3C%2FSPAN%3E%3CSPAN%3E%E5%8F%82%E6%95%B0%3C%2FSPAN%3E%3CSPAN%3Esrc%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%9AUSB%20HS%20PHY%20PLL%20%E6%97%B6%E9%92%9F%E6%BA%90%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E*%3C%2FSPAN%3E%3CSPAN%3E%E5%8F%82%E6%95%B0%3C%2FSPAN%3E%3CSPAN%3Efreq%3C%2FSPAN%3E%20%EF%BC%9A%E7%94%B1%3CSPAN%3Esrc%3C%2FSPAN%3E%3CSPAN%3E%E6%8C%87%E5%AE%9A%E7%9A%84%E9%A2%91%E7%8E%87%3C%2FSPAN%3E%3CSPAN%3E%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E*%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E*END**************************************************************************%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E9%9D%99%E6%80%81%3C%2FSPAN%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3ECLOCK_CONFIG_EnableUsbhs0PhyPllClock%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%3Euint32_t%3C%2FSPAN%3E%3CSPAN%3E%E9%A2%91%E7%8E%87%EF%BC%89%7B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3E%5B..%5D%3C%2FP%3E%3CP%3E%3CSPAN%3EUSBPHY-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3EPLL_SIC%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3B%3D%20~USBPHY_PLL_SIC_PLL_BYPASS_MASK%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F*%20%E6%B8%85%E9%99%A4%E6%97%81%E8%B7%AF%E4%BD%8D%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EUSBPHY-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3ECTRL%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3B%3D%20~USBPHY_CTRL_CLKGATE_MASK%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F*%20%E6%B8%85%E9%99%A4%E4%B8%BA%200U%20%E4%BB%A5%E8%BF%90%E8%A1%8C%E6%97%B6%E9%92%9F%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%2F*%20%E7%AD%89%E5%BE%85%E9%94%81%E3%80%82*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%BD%93%3C%2FSPAN%3E%3CSPAN%3E%EF%BC%88%EF%BC%81%EF%BC%88USBPHY-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3EPLL_SIC%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3B%20USBPHY_PLL_SIC_PLL_LOCK_MASK%EF%BC%89%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E0N65N%20Mask-Errata%20%23e9712%20%E4%B8%AD%E5%BB%BA%E8%AE%AE%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%B3%95%E6%97%A0%E6%B3%95%E8%BF%90%E8%A1%8C..%E5%8F%AF%E8%83%BD%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%9C%89%E4%BB%80%E4%B9%88%E5%BB%BA%E8%AE%AE%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1966342%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%85%B3%E4%BA%8E%20K26%20%E4%B8%8A%E7%9A%84%20USBHS%200N65N%20Mask-Errata%20%23e9712%EF%BC%88%E5%A6%82%E6%9E%9C%20MCG_C2%5BEREFS%5D%3D%200%EF%BC%8C%E5%88%99%E8%A7%A3%E9%94%81%20USBPHYPLL%EF%BC%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1966342%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E..%E5%B9%B6%E4%B8%94%20VBUS1%20%E6%B2%A1%E6%9C%89%E4%BE%9B%E7%94%B5%EF%BC%81%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1966330%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%85%B3%E4%BA%8E%20K26%20%E4%B8%8A%E7%9A%84%20USBHS%200N65N%20Mask-Errata%20%23e9712%EF%BC%88%E5%A6%82%E6%9E%9C%20MCG_C2%5BEREFS%5D%3D%200%EF%BC%8C%E5%88%99%E8%A7%A3%E9%94%81%20USBPHYPLL%EF%BC%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1966330%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%A7%A3%E5%86%B3%E4%BA%86%EF%BC%81%3C%2FP%3E%3CP%3EVREGIN0%2F1%20%E9%83%BD%E6%B2%A1%E6%9C%89%E4%BE%9B%E7%94%B5%EF%BC%8C%E8%BF%99%E4%BD%BF%E5%BE%97%20USB%20PHY%20%E9%9A%BE%E4%BB%A5%E6%93%8D%E4%BD%9C%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E
