USB suspend
USB suspend
2,427件の閲覧回数
martindusek
Contributor V
Is there any application note describing how to implement USB suspend mode (entering and exiting suspend mode) on Kinetis MCU?
3 返答(返信)
2,146件の閲覧回数
dspNeil
There are no App notes that I'm aware of. Can you be a bit more specific about what you're trying to achieve? Are you a USB host or device? Are you using a USB stack? Baremetal or RTOS?
As a device, for example, you could use Freescale's baremetal stack, and it will handle suspend for you. Stack version 4.1.1 added an example implementation for the TWR_K20D50M to the hid_keyboard example, that will put the device into STOP mode after the host issues a suspend.
2,146件の閲覧回数
martindusek
Contributor V
I'm sorry... I'm implementing USB suspend for USB device, using Freescale USB stack on bare metal.
I'll examine the hid_keyboard example. Thank you.
2,146件の閲覧回数
Monica
Senior Contributor III
Hello Martin, how is that turning out?
Please keep us posted :smileywink:
Monica
