USB device Bus Turnaround Timeout
7,273 次查看
martindusek
I adapted USB stack HID device example and made USB generic HID device. Unfortunately, I receive bus turnaround timeout error during enumeration after Device descriptor is sent. The consequence is that Windows doesn't recognize my device.
Can you please advise anything?
Martin
标记 (4)
4,909 次查看
martindusek
The issue has been solved - we forget to add 2u2 capacitor to VOUT33 pin. Therefore the output of the regulator was unstable.
4,909 次查看
DerekLau
If you have modified the example, please check the descriptors that you have modified.
If you haven't, please tell us what is the version of USB stack HID example and what device you are using.
4,910 次查看
martindusek
