UART library missing in code warrior for MKE04Z128
ravindra
we are working on MKE04Z128 controller,we UART communication with GSM module by using code warrior IDE,but some library missing in code warrior.we found that library in kinetics design studio.
we are in the stage of where we can not move/transfer the code into from code warrior to kinetics
kindly help us to get that library in code warrior,please refer the attached IDE library document for your reference
Omar_Anguiano
Hello ravindra
You can export the component from KDS in order to import the component into codewarrior. You can follow the steps described in chapter 3.3.9.5 Component(s) to component library of this user guide: https://www.nxp.com/files-static/soft_dev_tools/doc/user_guide/CWPEXUG.pdf
Let me know if this is helpful, if you have more questions do not hesitate to ask me.
Omar
Omar_Anguiano
Hello ravindra
Omar
