Typos in SDK 2.4.0
Typos in SDK 2.4.0
Keith4DSmith
To whom ever it may concern, attached is a list of many of the typos I have found in comments the USB middleware of the SDK 2.4.0 source. This is not an exhaustive list.
Tags (2)
danielchen
Hi Keith Smith
Thank you very much for your feedback, appreciated!
 I forwarded your input to the usb team, hopefully they can improve it in next release.
Have a nice day!
Keith4DSmith
Attached are additional errors found in the SDK 2.4.0. These are mostly around Doxygen syntax errors.
I received many warning '... not documented' from various SDK files.
danielchen
Thank you very much. will be fixed in SDK2.5.0
Keith4DSmith
I missed a few more typos.
danielchen
Thank you again.
Keith4DSmith
Daniel - Here's an additional list of typos in comments from SDK 2.4. [Can't seem to find how to attach a document to a reply.]
27Jun18
Filename
Line Number
Typo
fsl_edma.c
129, 143
periphral -> peripheral
fsl_edma.c
348
likned -> linked
fsl_edma.c
549
attibute -> attribute
fsl_edma.c
717
blcok -> block
fsl_edma.c
737
notfinished -> not finished
fsl_edma.c
870, 873
blcoks -> blocks
fsl_edma.h
242
stcd -> tcd
fsl_edma.h
258 (twice), 261
paramter -> parameter
fsl_edma.h
261
regsiter -> register
fsl_edma.h
802
preapre -> prepare
fsl_ftm.c
62
Syncronization -> Synchronization
fsl_ftfx_cache.c
457, 531
instaruction - > instruction
457, 531
cahce -> cache
fsl_ftfx_controller.c
542, 738
paramters -> parameters
547, 747
seperate -> separate
1378, 1392
gived -> given
fsl_ftfx_flash.c
503
inidicator -> indicator
fsl_ftfx_flash.h
398
programed -> programmed
517
uninitialzed -> uninitialized
fsl_ftxflexnvm.h
365
fsl_gpio.h
175, 195, 213, 238, 265, 295, 312, 365, 428, 448, 468, 488, 515, 544, 561
superceded -> superseded
fsl_lpuart.c
81, 93
addresss -> address
445
shoft -> shift
857
transmiter -> transmitter
fsl_lpuart.h
120
conuting -> counting
fsl_pit.h
129
onfiguration -> configuration
fsl_smc.c
159
Noraml -> Normal
fsl_uart.c
95
addresss -> address
316, 739
fsl_uart.h
95
165
paritye -> parity
fsl_debug_console_conf.h
49, 61
ultilization -> utilization
62
overwrited -> overwritten
fsl_log.c
158
calucate -> calculate
223, 225, 226, 234
avaliable -> available
365, 432
recieve -> receive
497
losed -> lost
fsl_log.h
86, 98, 123
99, 108
recieved -> received
fsl_str.c
935
convernsion -> conversion
fsl_str.h
67
callbck -> callback
fsl_clock.c
231
regardness -> regardless
779
fequency -> frequency
fsl_clock.h
72
contol -> control
967
internall -> internal
968, 982
confuration -> configuration
1395, 1413
souce -> source
1466, 1478, 1481
sytem -> system
fsl_common.c
42
adress -> address
fsl_common.h
494
convinience -> convenience
MK22F1212_features.h
57
acces -> access
80
remamed -> renamed
danielchen
Hi Keith Smith
Thanks again.   Please use advanced editor attaching your document in a reply
