Two different clock configurations using Processor Expert with FRDM-KL25Z board?
986件の閲覧回数
mikeconover
Is there anyway to use two different clock configurations using Processor Expert? If so, how do I do this. I am using MQX Lite with the FRDM-KL25Z board. I want to put the application in low power mode after I go through a state machine talking on the serial port. My problem is that when I try enabling low power mode, I am not able to produce 9600 baud with the AsynchroSerial driver.
Mike
844件の閲覧回数
adriancano
First you need to have two clock configurations for the CPU component, check the image below, here configuration 0 is configured in PEE mode and the configuration 1 is configured in BLPI mode allowing low power modes.
In the Serial component enable the component in both clock configurations and set a baud rate that both configurations can achieve.
I hope this information can help you.
Note: If this post answers your question, please click the Correct Answer button. It would be nice!
