Trying to load an OpenSDA Application
ソリューションへジャンプ
3,085件の閲覧回数
blazerogers
Im working with the kl02. when I try to copy/paste the file (MSD-FRDM- KL02Z_v108_Pemicro.SDA)to the boot loader then unplug/plug the usb in I can't get the FRDM-KL02Z drive to show up. Any suggestions would help.
ラベル(2)
タグ(4)
2,948件の閲覧回数
kerryzhou
Hi blaze rogers,
    As I know, macbook with os X YOSEMITE  is not ok, you should better use the computer with  Window 7 os.
    If you use Window 8, you should follow the first FAQ from PEmicro opensda, the link is :
http://www.pemicro.com/opensda/faqs/faqs.cfm
Wish it helps you!
Jingjing
3 返答(返信)
2,948件の閲覧回数
yasuhikokoumoto
Senior Contributor I
I guess you did the procedures on Windows8.x.
The bootloader update of OpenSDAv1 will fail on Windows8.x.
You should do them on Windows7.
Yasuhiko Koumoto.
2,948件の閲覧回数
blazerogers
And what about on a macbook pro with os x yosemite?
2,948件の閲覧回数
kerryzhou
Hi blaze rogers,
Wish it helps you!
Jingjing
