Tring to flash K10 from binary or read flash
1,507 次查看
Fred_Eric
I am not familiar with the K10 and I am trying to figure out how to flash it from a binary file that I have (this binary is a file that is read by a touchscreen controller connected to the main board having the K10).
Another option could be to read from another board as I have few working boards.
I have tried few things (converted the binary then flash it) but never got any success. I have done the same kind of thing with boards with PIC easily but this one is new to me.
I also tried to connect the controller to the board with a brand new K10 but the touch screen controller is not seeing the board (probably because there's now firmware and boot loader).
Thanks!
Fred
1,475 次查看
Ricardo_Zamora
Hello Fred,
Hope you are doing well. If you have your code project, you can use an external Debugger/Programmer.
Just, be sure that the Debug interface is correct. Please refer to section 2.1.5.3 of KQRUG, Kinetis K Quick Reference User Guide.
Ricardo
