TWR-KE18F erase debug K20
3,012 次查看
tobias_mrs
Hello
I using a TWR-KE18F demoboard.
And now it looks like that I accidentally deleted the firmware of the K20 debug interface.
It don't build a USB connection ore connection if I connect it with pressed reset button.
How can I restore the debug firmware of the K20 with a PE-Micro Multilink?
2,954 次查看
Robin_Shen
Of course
Please refer: Recovering and Updating the NXP OpenSDA Bootloader with P&E Multilink and MCUXpresso IDE
Robin
4 回复数
2,954 次查看
tobias_mrs
Hello
Sorry but I don't find any USB Storage device. I tested it with windows and linux, but I don't find any board connected to USB.
Is there any possibility to flash it via PE-Micro Multilink Universal?
Tobias
2,955 次查看
Robin_Shen
Of course
Robin
2,954 次查看
tobias_mrs
Thank you for the Link. That was the solution.
Best Reagrads
Tobias
2,954 次查看
Robin_Shen
Please refer DAPLink bootloader update and then check the state of your board.
The firmware can be found in INTERFACE FIRMWARE UPDATES.
Robin
