TWR-K70F120M + TWR-PROTO-ND without TWR-ELEV possible?
Keypuncher
I have a TWR-K70F120M, can I use the prototype board (TWR-PROTO-ND) without the elevators (TWR-ELEV)?
I was wanting to see if I could add some simple passive components by connecting one side of the prototype board to one side of the K70 board.
xiangjun_rong
This is the schematics of TWR-PROTO:
https://www.nxp.com.cn/downloads/en/schematics/SCH-26187.pdf
The TWR-ELEV board can connect the primary side signals of TWR-K70F120M to the TWR-PROTO board.
If you do not want to use TWR-ELEV, pls refer to  the schematics of TWR-K70F120M and check if you can connect the signals of TWR-K70F120M to the TWR-PROTO board, in other words, if the signals on TWR-K70F120M board you want to connect to are connected to a connector on the TWR-K70F120M board so that you can use flying cable to connect them. so it is case by case.
Hope it can help you
XiangJun Rong
xiangjun_rong
XiangJun Rong
%3CLINGO-SUB%20id%3D%22lingo-sub-1841047%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ETWR-K70F120M%20%2B%20TWR-PROTO-ND%20without%20TWR-ELEV%20possible%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1841047%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EI%20have%20a%20TWR-K70F120M%2C%20can%20I%20use%20the%20prototype%20board%20(TWR-PROTO-ND)%20without%20the%20elevators%20(TWR-ELEV)%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EI%20was%20wanting%20to%20see%20if%20I%20could%20add%20some%20simple%20passive%20components%20by%20connecting%20one%20side%20of%20the%20prototype%20board%20to%20one%20side%20of%20the%20K70%20board.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1841647%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20TWR-K70F120M%20%2B%20TWR-PROTO-ND%20without%20TWR-ELEV%20possible%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1841647%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3EThis%20is%20the%20schematics%20of%20TWR-PROTO%3A%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com.cn%2Fdownloads%2Fen%2Fschematics%2FSCH-26187.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com.cn%2Fdownloads%2Fen%2Fschematics%2FSCH-26187.pdf%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EThe%20TWR-ELEV%20board%20can%20connect%20the%20primary%20side%20signals%20of%20TWR-K70F120M%20to%20the%20TWR-PROTO%20board.%3C%2FP%3E%0A%3CP%3EIf%20you%20do%20not%20want%20to%20use%20TWR-ELEV%2C%20pls%20refer%20to%26nbsp%3B%20the%20schematics%20of%20TWR-K70F120M%20and%20check%20if%20you%20can%20connect%20the%20signals%20of%20TWR-K70F120M%20to%20the%20TWR-PROTO%20board%2C%20in%20other%20words%2C%20if%20the%20signals%20on%20TWR-K70F120M%20board%20you%20want%20to%20connect%20to%20are%20connected%20to%20a%20connector%20on%20the%20TWR-K70F120M%20board%20so%20that%20you%20can%20use%20flying%20cable%20to%20connect%20them.%20so%20it%20is%20case%20by%20case.%3C%2FP%3E%0A%3CP%3EHope%20it%20can%20help%20you%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EXiangJun%20Rong%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CH2%20class%3D%22message-subject%22%20id%3D%22toc-hId--1212332555%22%20id%3D%22toc-hId--496605549%22%3E%3CSTRONG%3E%3CSPAN%20class%3D%22lia-message-read%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FH2%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
