TPM timer initial delay when using 32kHz EXTAL
1,798 次查看
jpatel1
I'm trying to use TPM clock on KL17 using external 32kHz crystal. I've initialized MOD value with 32, so expecting it to interrupt after 1ms.
But I always get the first interrupt from tpm counter after 120ms delay, subsequent interrupts happen at 1ms interval.
Any pointers to debugging this issue?
1,654 次查看
jpatel1
Thanks Vincente for the response!
I am using gpio pin toggle when I initialize TPM timer and when I receive interrupt; measuring the delay using oscilloscope.
what is the best way to verify in code if crystal/clock stabilization has happened?
I am using VLPS3 sleep mode with RTC configured for external crystal. I was expecting the delay will not happen when waking up from sleep as OSC still running in sleep mode. What am I missing here?
1,654 次查看
vicentegomez
How are you measuring the first pulse, remember you will need to add the time for the clock stabilization
