Source code for CM4_MMCLIB and CM4_ACLIB
1,112 次查看
ilantiagai
Hi, is the source code for CM4_MMCLIB library (the library containing motor control, general math, and filter algorithms) and  the CM4_ACLIB library (advanced control algorithms for rotor position) available anywhere?
1,024 次查看
Carlos_Mendoza
Hi Ilan,
You can download the embedded Software Motor Control and Power Conversion Libraries from this page:
Embedded Software Motor Control and Power Con|NXP
Hope it helps!
Carlos Mendoza
Technical Support Engineer
