Source Code for K60 Serial Bootloader?
3,769 次查看
danielchai
Senior Contributor I
Hi All,
Where could I find the source code for the serial bootloader for K60?
Thank you.
-Daniel
3,139 次查看
anthony_huereca
Hi Daniel,
  You can find the software package here, which has K60 projects: Software for AN2295
  Also in order to save pins, by default the bootloader does not use a pin to enter bootloader mode, it uses the UART. This is configurable though. See section 2.1 of the app note.
Anthony
4 回复数
3,139 次查看
ZhangJennie
please search an2295 in Freescale web site, it covers serial bootloader for kinetis.
3,139 次查看
danielchai
Hi Jun,
I read the AN2295, but there is no code for K60. One more thing is that if I want K60 to go to bootloader, which pin should I pull low?
Thank you.
3,140 次查看
anthony_huereca
Hi Daniel,
Anthony
3,139 次查看
dominikf
The link was down. With some searching I found the source code package here: http://cache.freescale.com/files/microcontrollers/doc/app_note/AN2295SW.zip
Cheers,
Dominik
