Schematics to implement power sequencing of MK70FN1M0VMJ12
893 次查看
puspamnayak
Greetings for the day !!!
I am using MK70FN1M0VMJ12 in my project so request you to provide schematics for reference to implement Power-Up and Power-Down sequence in my design.
As per page no. 27 of datasheet I need to follow the power sequencing in my design. I have referred  Tower board schematics but not getting the power section where this power sequencing is implemented
Kindly help me regarding this
Thanks and Regards,
Puspam Nayak
标记 (1)
771 次查看
chris_brown
Hi Puspam,
The power sequencing on the tower board is guaranteed by sourcing the VDD, VDD_int, and VDDA power pins from the same electrical node (and therefore, the same source).  VDD_DDR is sourced from a power regulator downstream of the P3V3 source (which powers the other domains).  So we rely on the cascaded power supply to guarantee that VDD_DDR is powered after the other supplies.  Does this make sense?
Hope this helps,
Chris
