SIM Macro activation in MCUxpresso
496 次查看
ve3id
I'm picking up an old project that was originally built using KDE and later modified using mcuexpresso.
I downloaded the latest version of the IDE and created a new C/C++ project using SDK2.11.0 for the FRDM_K64F board which I have.
I'm copying code from the old project as it had all sorts of stuff I don't want anymore and am trying to build up in the new project from scratch.
The first code I pasted in was a port initialisation.
Problem is when I compile I get "undefined'' errors on all hardware references:
./source/Frere_2016.c:52:1: error: 'SIM_SCGC5' undeclared (first use in this function)
52 | SIM_SCGC5 |= SIM_SCGC5_PORTA_MASK; // Enable Port A Clock Gate C
I have unzipped the SDK with no difference.
It seems that the original source code must have had some assignment made which I am not copying, but surely that should be covered in a new project by the following:
#include <stdio.h>
#include "board.h"
#include "peripherals.h"
#include "pin_mux.h"
#include "clock_config.h"
#include "fsl_debug_console.h"
I even tried adding #include "MK64F12.h" to no avail
Any help really apprecaited!
Nigel
So I started
440 次查看
Hello @ve3id
The compile error happens because SIM_SCGC5 is an old Kinetis register symbol; in MCUXpresso SDK 2.x for FRDM-K64F you should use SIM->SCGC5 and similarly convert the other hardware register references to PERIPHERAL->REGISTER syntax.
For you specific line, change
to
SIM->SCGC5 |= SIM_SCGC5_PORTA_MASK;
Thank you.
Alice
406 次查看
ve3id
Thank you very much, Alice.  You are so knowledgeable that you make it look easy!
Now I can get on with my project
cheers
Nigel
%3CLINGO-SUB%20id%3D%22lingo-sub-2387889%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMCUxpresso%20%E4%B8%AD%E7%9A%84%20SIM%20%E5%AE%8F%E6%BF%80%E6%B4%BB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2387889%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E6%8E%A5%E6%89%8B%E4%B8%80%E4%B8%AA%E6%97%A7%E9%A1%B9%E7%9B%AE%EF%BC%8C%E8%AF%A5%E9%A1%B9%E7%9B%AE%E6%9C%80%E5%88%9D%E4%BD%BF%E7%94%A8%20KDE%20%E7%89%88%E6%9C%AC%EF%BC%8C%E5%90%8E%E6%9D%A5%E4%BD%BF%E7%94%A8%20mcuexpresso%20%E8%BF%9B%E8%A1%8C%E4%BA%86%E4%BF%AE%E6%94%B9%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%B8%8B%E8%BD%BD%E4%BA%86%E6%9C%80%E6%96%B0%E7%89%88%E6%9C%AC%E7%9A%84%20IDE%EF%BC%8C%E5%B9%B6%E4%BD%BF%E7%94%A8%20SDK2.11.0%20%E4%B8%BA%E6%88%91%E7%9A%84%20FRDM_K64F%20%E6%9D%BF%E5%88%9B%E5%BB%BA%E4%BA%86%E4%B8%80%E4%B8%AA%E6%96%B0%E7%9A%84%20C%2FC%2B%2B%20%E9%A1%B9%E7%9B%AE%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BB%8E%E6%97%A7%E9%A1%B9%E7%9B%AE%E4%B8%AD%E5%A4%8D%E5%88%B6%E4%BB%A3%E7%A0%81%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%AE%83%E5%8C%85%E5%90%AB%E4%BA%86%E5%BE%88%E5%A4%9A%E6%88%91%E4%B8%8D%E5%86%8D%E9%9C%80%E8%A6%81%E7%9A%84%E4%B8%9C%E8%A5%BF%EF%BC%8C%E8%80%8C%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E5%9C%A8%E6%96%B0%E9%A1%B9%E7%9B%AE%E4%B8%AD%E4%BB%8E%E5%A4%B4%E5%BC%80%E5%A7%8B%E6%9E%84%E5%BB%BA%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E7%B2%98%E8%B4%B4%E7%9A%84%E7%AC%AC%E4%B8%80%E6%AE%B5%E4%BB%A3%E7%A0%81%E6%98%AF%E7%AB%AF%E5%8F%A3%E5%88%9D%E5%A7%8B%E5%8C%96%E4%BB%A3%E7%A0%81%E3%80%82%3C%2FP%3E%3CP%3E%E9%97%AE%E9%A2%98%E6%98%AF%EF%BC%8C%E7%BC%96%E8%AF%91%E6%97%B6%E6%89%80%E6%9C%89%E7%A1%AC%E4%BB%B6%E5%BC%95%E7%94%A8%E9%83%BD%E5%87%BA%E7%8E%B0%E2%80%9C%E6%9C%AA%E5%AE%9A%E4%B9%89%E2%80%9D%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FP%3E%3CP%3E.%2Fsource%2FFrere_2016.c%3A52%3A1%3A%20%E9%94%99%E8%AF%AF%3A%20%E6%9C%AA%E5%A3%B0%E6%98%8E%E7%9A%84%E2%80%9CSIM_SCGC5%E2%80%9D%EF%BC%88%E5%9C%A8%E6%AD%A4%E5%87%BD%E6%95%B0%E4%B8%AD%E9%A6%96%E6%AC%A1%E4%BD%BF%E7%94%A8%EF%BC%89%3CBR%20%2F%3E%2052%20%7C%20SIM_SCGC5%20%7C%3D%20SIM_SCGC5_PORTA_MASK%3B%20%2F%2F%20%E4%BD%BF%E8%83%BD%E7%AB%AF%E5%8F%A3%20A%20%E6%97%B6%E9%92%9F%E9%97%A8%20C%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E8%A7%A3%E5%8E%8B%E4%BA%86SDK%EF%BC%8C%E4%BD%86%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E5%8F%98%E5%8C%96%E3%80%82%3C%2FP%3E%3CP%3E%E7%9C%8B%E6%9D%A5%E5%8E%9F%E5%A7%8B%E6%BA%90%E4%BB%A3%E7%A0%81%E4%B8%AD%E8%82%AF%E5%AE%9A%E6%9C%89%E4%B8%80%E4%BA%9B%E6%88%91%E6%B2%A1%E6%9C%89%E5%A4%8D%E5%88%B6%E7%9A%84%E8%B5%8B%E5%80%BC%E8%AF%AD%E5%8F%A5%EF%BC%8C%E4%BD%86%E8%BF%99%E5%BA%94%E8%AF%A5%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%E4%BB%A5%E4%B8%8B%E6%96%B9%E5%BC%8F%E5%9C%A8%E6%96%B0%E9%A1%B9%E7%9B%AE%E4%B8%AD%E5%AE%9E%E7%8E%B0%EF%BC%9A%3C%2FP%3E%3CP%3E%23include%20%3CSTDIO.H%3E%3CBR%20%2F%3E%23include%20%22board.h%22%3CBR%20%2F%3E%23include%20%22peripherals.h%22%3CBR%20%2F%3E%23include%20%22pin_mux.h%22%3CBR%20%2F%3E%23include%20%22clock_config.h%22%3CBR%20%2F%3E%23include%20%22fsl_debug_console.h%22%3C%2FSTDIO.H%3E%3C%2FP%3E%3CP%3E%E6%88%91%E7%94%9A%E8%87%B3%E5%B0%9D%E8%AF%95%E6%B7%BB%E5%8A%A0%E4%BA%86%20%23include%20%22MK64F12.h%22%EF%BC%8C%E4%BD%86%E4%BB%8D%E7%84%B6%E6%97%A0%E6%95%88%E3%80%82%3C%2FP%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%EF%BC%81%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%E5%A5%88%E6%9D%B0%E5%B0%94%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%E4%BA%8E%E6%98%AF%E6%88%91%E5%BC%80%E5%A7%8B%E4%BA%86%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2388132%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SIM%20Macro%20activation%20in%20MCUxpresso%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2388132%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F460%22%20target%3D%22_blank%22%3E%40ve3id%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E7%BC%96%E8%AF%91%E9%94%99%E8%AF%AF%E5%8F%91%E7%94%9F%E7%9A%84%E5%8E%9F%E5%9B%A0%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CCODE%20class%3D%22%22%3ESIM_SCGC5%3C%2FCODE%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%E8%BF%99%E6%98%AF%E4%B8%80%E4%B8%AA%E6%97%A7%E7%9A%84%20Kinetis%20%E5%AF%84%E5%AD%98%E5%99%A8%E7%AC%A6%E5%8F%B7%EF%BC%9B%E5%9C%A8%20MCUXpresso%20SDK%202.x%20%E7%9A%84%20FRDM-K64F%20%E7%89%88%E6%9C%AC%E4%B8%AD%EF%BC%8C%E6%82%A8%E5%BA%94%E8%AF%A5%E4%BD%BF%E7%94%A8%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CCODE%20class%3D%22%22%3ESIM-%26gt%3BSCGC5%3C%2FCODE%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%E7%B1%BB%E4%BC%BC%E5%9C%B0%EF%BC%8C%E5%B0%86%E5%85%B6%E4%BB%96%E7%A1%AC%E4%BB%B6%E5%AF%84%E5%AD%98%E5%99%A8%E5%BC%95%E7%94%A8%E8%BD%AC%E6%8D%A2%E4%B8%BA%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CCODE%20class%3D%22%22%3EPERIPHERAL-%26gt%3BREGISTER%3C%2FCODE%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%E5%8F%A5%E6%B3%95%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E9%92%88%E5%AF%B9%E6%82%A8%E7%9A%84%E7%89%B9%E5%AE%9A%E7%BA%BF%E8%B7%AF%EF%BC%8C%E8%BF%9B%E8%A1%8C%E6%9B%B4%E6%94%B9%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22token%22%3ESIM_SCGC5%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22token%22%3E%7C%3D%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22token%22%3ESIM_SCGC5_PORTA_MASK%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22token%22%3E%EF%BC%9B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22token%22%3E%E5%88%B0%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22token%22%3ESIM-%26gt%3BSCGC5%20%7C%3D%20SIM_SCGC5_PORTA_MASK%EF%BC%9B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22token%22%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22token%22%3EBR%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22token%22%3E%E7%88%B1%E4%B8%BD%E4%B8%9D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2388570%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SIM%20Macro%20activation%20in%20MCUxpresso%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2388570%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E4%BD%A0%EF%BC%8C%E7%88%B1%E4%B8%BD%E4%B8%9D%E3%80%82%E4%BD%A0%E7%9F%A5%E8%AF%86%E6%B8%8A%E5%8D%9A%EF%BC%8C%E5%81%9A%E8%B5%B7%E6%9D%A5%E5%8D%B4%E6%AF%AB%E4%B8%8D%E8%B4%B9%E5%8A%9B%EF%BC%81%3C%2FP%3E%3CP%3E%E7%8E%B0%E5%9C%A8%E6%88%91%E5%8F%AF%E4%BB%A5%E7%BB%A7%E7%BB%AD%E6%88%91%E7%9A%84%E9%A1%B9%E7%9B%AE%E4%BA%86%E3%80%82%20%3CLI-EMOJI%20id%3D%22lia_slightly-smiling-face%22%20title%3D%22%3Aslightly_smiling_face%3A%22%3E%3C%2FLI-EMOJI%3E%3C%2FP%3E%3CP%3E%E5%B9%B2%E6%9D%AF%3C%2FP%3E%3CP%3E%E5%A5%88%E6%9D%B0%E5%B0%94%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
