SDRAM and Parallel NOR flash interfacing with MK26FN2M0VLQ18
1,065件の閲覧回数
prasannanaik
   I want to interface SDRAM and Parallel NOR flash with MK26FN2M0VLQ18. There's not much information on the flexbus interface. Can i get some documents regarding flexbus?.Also can you also suggest some application note regarding the same.
Prasanna
980件の閲覧回数
miduo
You may would like to make reference this application note on "Multiplexing Pins Between SDRAM and
FLEXBUS on K65/K66"  https://www.nxp.com/docs/en/application-note/AN5095.pdf
  K65 is a superset of the K26 with Ethernet.
