SDIO MK64FN...
SDIO MK64FN...
1,634 次查看
evangeloskaloud
I am trying to make MK64FN's SDIO work as a communication bus and not as a file system.
I am also trying to make it work with ADMA2 as well.
I have done some things (that are far from presentable :smileyhappy: ) but I would very much appreciate some reference!
Thank you,
/Vagelis
1,475 次查看
soledad
Hello Vagelis,
Please check the below thread and let me know if this helps.
SDHC working with DMA
Sol
1,475 次查看
evangeloskaloud
Thank you for your answer. The main question is on how to use the SDIO (NOT with fatfs). All examples (even from other freedom boards) are for fatfs.
DMA communication is not such a high priority,
Thank you,
Vagelis
