SC16P RTC_CR for MK22FN128VDC10
ソリューションへジャンプ
2,634件の閲覧回数
thoomanwang
Contributor V
RTC_CR has a field SC16P for MK22FN128VDC10
Whether I use RTC_CR to configure external crystal vibration load capacitance, no longer need to welding load resistance?
ラベル(2)
2,463件の閲覧回数
kerryzhou
Hi Thooman,
You are welcome.
 If you still have question, just let me know.
 If your question is solved, please help use to click the correct answer to mark your question as resolved.
Kerry
3 返答(返信)
2,463件の閲覧回数
kerryzhou
Hi Thooman,
     If you use the internal capacitor by configuring the RTC_CR, and your board's crystal can oscillating after enable the OSC, then you don't need to welding external load capacitor.
     But I suggest you add the external capacitor pcb package for the hardware crystal circuit testing.
Wish it helps you!
If you still have question, please let me know!
Kerry
2,463件の閲覧回数
thoomanwang
Contributor V
Thanks!!!
2,463件の閲覧回数
kerryzhou
Hi Thooman,
You are welcome.
Kerry
