Reset pin voltage of microcontroller
1,367件の閲覧回数
madhusharmak
I'm using a kinetics microcontroller with part number MK61FN1M0VMJ12. After powering the device, I'm getting about 1.1V across the RESET Pin which is neither high ( 3.3V) nor low. Please let me know whether this is the expected voltage when the device is not programmed.
Thanking you
Madhu Sharma
1,226件の閲覧回数
Robin_Shen
Hi Madhu Sharma
The the waveform on RESET_b Pin may seems periodic oscillation if the device is not programmed.
You can check the circuits according to the "2.1.3.4.1 RESET_b and NMI_b" of KQRUG.pdf
Best Regard
Robin
