Required example code for Compute elliptic curve authentication based LTC driver with MK82 hardware
2,694 次查看
Thiru_S
We need example code for Compute elliptic curve authentication using LTC driver with MK82 hardware
if anyone having idea or example code, please share with me.
The example must use the LTC_PKHA_ECC_PointMul  these APIs to develope ECDH key exchange algorithm.
Thanks in advance.
Kind Regards,
Thiru.
2,667 次查看
Alexis_A
Hello @Thiru_S,
In the SDK you can find the mbedtls library and some examples that could help with your application, unfortunately, there isn't a specific example using the LTC_PKHA_ECC_PointMul.
Alexis Andalon
2,652 次查看
Thiru_S
Thank you Alexis
2,668 次查看
Alexis_A
Hello @Thiru_S,
Alexis Andalon
