Req -- Need for datasheet -- SCK10DX128T3VLH5
2,169件の閲覧回数
sanminavenkat
Dear NXP/Freescale team,
        Hi, This is venkat from sanmina chennai, Supplier Quality, We are using the below part for incoming inspection purpose, the datasheet not available in your website, So pls provide the datasheet....
Philips P/N:453564400241
MPN : - SCK10DX128T3VLH5
MFR : - FREESCALE
DES :- IC ARM CORTEX M4 K10DX128 LQFP64
NOTE :- This is Philips project for sanmina singapore
3 返答(返信)
2,010件の閲覧回数
miduo
I can not find the part number you mentioned from our data base. Please help to double check. Did you mean the part: MK10DX128VLH5? The data sheet for this part is as below:
http://www.nxp.com/files/32bit/doc/data_sheet/K10P64M50SF0.pdf
2,010件の閲覧回数
sanminavenkat
Dear All,
The below part datasheet not available in your website, So pls provide
the datasheet for asap..
MPN :- VY22490-5
MFR :- NXP
DES :- IC ASIC SWORDFISH FPBGA204 ROHS COMPLI
*Thanks & Regards, *
Venkatesan.G
SQA
2,010件の閲覧回数
vicentegomez
I Venkatesan
The SCK10DX128T3VLH5 is a custom part, we can not share the data sheet for custom parts. You need to ask to your customer for the data sheet.
Vicente Gomez
